mike sentiff
#1 Posted : Wednesday, February 6, 2008 3:57:15 PM(UTC)
mike sentiff
I have a 15 yr old sensi dry hotpoint dryer. A year ago the timed cycle stop drying - it tries but it does not heat (once in great while it will) but the sensi dry still worked
Now on sensi dry the first 4/5 loads dry great then the next 2 are sort of damp then the next 2 are good then the rest of the loads are wet- maybe it drys them maybe not
Checked the vent -clear, check continuety on thermostat-ok - checked the coils - @ 1300-1400 ohms - ok. turn on the dryer and
The ignitor glows on @ 10 seconds later the flame comes on (ignitor goes out) heATS 2/3 minutes - flame out and we repeat this cycle again once the dryer cools off.
I have no clue at this time- any help or ideas?
#2 Posted : Wednesday, February 6, 2008 4:54:49 PM(UTC)
Replace the gas valve coils, a common problem with these syptoms.
mike sentiff
#3 Posted : Thursday, February 7, 2008 4:16:52 AM(UTC)
mike sentiff
Rich
Thanks for the help - it looked like i was going in that direction --
Even though both coils read 1300 ohms That is a false reading
and should i replace both of them
Mike:confused:
#4 Posted : Thursday, February 7, 2008 7:20:14 AM(UTC)
Resistance readings are useless,they will not show shorted turns. They come as a pair anyway, so just replace them.
