JMicheal
#1 Posted : Wednesday, February 6, 2008 3:39:04 PM(UTC)
JMicheal
The dryer stops before the clothes are dry. This happens whether it is on the moisture setting or timed drying. I did recently clean out the vent and pipes (which were heavily clogged). However, that did not seem to help.
Any advice?
#2 Posted : Wednesday, February 6, 2008 5:47:12 PM(UTC)
Run a couple loads with the vent hose disconnected from the dryer.
Post the result.
For more accurate advise I need the complete model number of the dryer.
Guest (4)
Dryer stops before clothes are dry (Dryer Repair)
by BJE 7/14/2012 6:00:59 AM(UTC)
