On flat bottom pan and correct position of knob at the setting 4-5 was working slowly red heating and cooling.Now it goes fast red hot and quickly shutus off.What must have to be change to make it work originally? Thanks Babu
Originally Posted by: Gene  Hi Gene Thanks can you tell me which part(Switch)I should buy. And how much it is. The switch faulty hailent 8 inch elment is AP2027787. Is this switch is easily replacable. Thanks Sincerely Babu
The switch Part number: AP2024074
If you are somewhat handy then this part is not too difficult to replace yourself. Gene.
Originally Posted by: Gene  The switch Part number: AP2024074
If you are somewhat handy then this part is not too difficult to replace yourself. Gene. Gene Why it does not list in the GE Stove Model JBP80 ? If you see under the part used for the Model list. Thanks Babu
It is listed as #19 on the diagram. Gene.
Gene I got the part but I have difficulties to remove the connector crimp spade from back of the existing connector, it is tight. Do you suggest any tool or how to detache the lug part. Thanks babu
Try to pry it with a flat blade screwdriver.
