Babupatel
#1 Posted : Monday, August 3, 2009 10:33:50 AM(UTC)
Babupatel
On flat bottom pan and correct position of knob at the setting 4-5 was working slowly red heating and cooling.Now it goes fast red hot and quickly shutus off.What must have to be change to make it work originally? Thanks
Babu
#2 Posted : Tuesday, August 4, 2009 10:00:52 AM(UTC)
Most likely the problem is a bad switch for this burner.
Here are the breakdown diagrams and Replacement parts for GE JBP80WH1WW | AppliancePartsPros.com
Babupatel
#3 Posted : Wednesday, August 5, 2009 7:09:26 AM(UTC)
Babupatel
Hi Gene
can you tell me which part(Switch)I should buy. And how much it is.
The switch faulty hailent 8 inch elment is AP2027787.
Is this switch is easily replacable.
Sincerely
Babu
#4 Posted : Friday, August 7, 2009 5:08:28 PM(UTC)
The switch Part number: AP2024074
If you are somewhat handy then this part is not too difficult to replace yourself.
Babupatel
#5 Posted : Monday, August 10, 2009 11:23:29 AM(UTC)
Babupatel
Why it does not list in the GE Stove Model JBP80 ?
If you see under the part used for the Model list.
Babu
#6 Posted : Monday, August 10, 2009 11:45:27 AM(UTC)
It is listed as #19 on the diagram.
Babupatel
#7 Posted : Friday, October 23, 2009 7:33:12 AM(UTC)
Babupatel
I got the part but I have difficulties to remove the connector crimp spade from back of the existing connector, it is tight. Do you suggest any tool or how to detache the lug part.
babu
#8 Posted : Friday, October 23, 2009 12:55:35 PM(UTC)
Try to pry it with a flat blade screwdriver.
Guest (5)
