jaywoods102
#1 Posted : Friday, October 23, 2009 9:02:06 AM(UTC)
jaywoods102
i just got this fridg. a day later water is building in bottom of freezer and running onto floor
magician59
#2 Posted : Friday, October 23, 2009 9:22:54 AM(UTC)
magician59
Remove the rear panel inside the freezer section and check the drain for a restriction or clog. The drain is a pencil-sized hole in the center under the evaporator coil.
jaywoods102
#3 Posted : Friday, October 23, 2009 9:43:50 AM(UTC)
jaywoods102
when i turn off icemaker leaks seams to stop.would this still be a drain problem
magician59
#4 Posted : Friday, October 23, 2009 9:48:50 AM(UTC)
magician59
Do you notice water overflowing from the ice maker when it's on?
