I have changed the thermostat,tested the heating elements for resistance,tested the timer for voltage out on defrost cycle. all are good but it still won't defrost. what am I missing? please help :confused:
Would it defrost if you turn the defrost timer manually? If the answer is Yes, then the defrost timer is the culprit. - The defrost timer Part number: AP2061695
