billjoe
#1 Posted : Tuesday, October 20, 2009 9:32:05 AM(UTC)
billjoe
My Whirlpool elect. dryer is making a lot of noise and walks forward. Even though it is level. Any ideas what's causing this?
#2 Posted : Wednesday, October 21, 2009 3:31:39 AM(UTC)
Replacement parts for WHIRLPOOL LEQ9558KQ1 | AppliancePartsPros.com
You will have to open it up and check.
At the top of my list would be the rear support rollers. One of them may have a flat spot or a totally shot bearing.
Check the channel on the drum where the rear rollers ride.
Next would be has anything come loose.
If it is a rear roller be sure to check that it's shaft is OK just in case that also needs replacing.
Also check that the paddle in the drum is secure.
I would probably check the belt, the idler wheel, front bearing ring etc.
Replace as necessary.
Basically do an overhaul.
Also a good idea to clean/check your vent system.
billjoe
#3 Posted : Monday, October 26, 2009 7:55:05 AM(UTC)
billjoe
Thank you so much for the information. It was right on. I replaced the suggested parts and the dryer works fine now. Thanks again
