Originally Posted by: SWKRO ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thank you. Can you give me a liitle bit more detailed "how to" I thought I saw a previous poster who had some pictures, but now I cant find the post. I have very limited electrical skill, but can follow directions well. [LIST=1]
What is a jumper? How do I jump? What specific pins get jumped? Is there a schematic of the motherboard?[/LIST]Also, If I replace the thermister (it looks like it is fried, it has brown/black ooze at the bootom) can I just splice it to the exitsing white wire? I noticed a harness/plug behind the ice maker that looks too hard to get to. Would I also be able to do the same with the defrost thermostat?
Appreciate the help!! Sorry again...I have the same questions that you did? Would you kindly answer these questions please? Thank you very much. Also, how quick did you get your order delivered? I'll start ordering on this site, thanx
Muthaboard should be on the back (outside of your fridge) it will have a cover over it. You need to UNPLUG the power before you open the cover. The thermister & defrost thermostat are inside the freezer unit, clipped onto the evaporative coil. You need to Google your fridge model and see what you can come up with on other sites. You can not work blindly without a diagram to see where verything is located on you model. The evaporative coils are covered by a plate inside the freezer. If you installed the defrost element yourself, what that defrosts is the ice build up on the coil.
Yes, I replaced the def heater by myself (very proud haha)...the company that came over wanted to charge me $275 in addition to the $65 diagnose fee...I replaced it with a double (dual element heater) and it worked for over a week but now back to square one...but I'll google it to come up with its diagram....thanks so much for getting back to me quickly...I'll post any info they give me if there's any recalls from GE...again thanxx ;)
Originally Posted by: gerefriGSS22JERFWW ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Sorry again...I have the same questions that you did? Would you kindly answer these questions please? Thank you very much. Also, how quick did you get your order delivered? I'll start ordering on this site, thanx Jumpers are little alligator clip jumper cables that you get from Radio Shack. I tried to give you a link, but it wont post on this site, Please GOOGLE your make/model# & problem
Originally Posted by: SWKRO ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Muthaboard should be on the back (outside of your fridge) it will have a cover over it. You need to UNPLUG the power before you open the cover. The thermister & defrost thermostat are inside the freezer unit, clipped onto the evaporative coil. You need to Google your fridge model and see what you can come up with on other sites. You can not work blindly without a diagram to see where verything is located on you model. The evaporative coils are covered by a plate inside the freezer. If you installed the defrost element yourself, what that defrosts is the ice build up on the coil. Thanks for telling me about unplugging the power...the tech that came over didn't unplug the the power when he removed the defrost heater...I'm looking forward to conquering the beast myself hahaha :cool:
HI SWKRO Thanks for the info. Hopefully it's a part and not the motherboard. Thanks again Grumps
Thanks for the link Grumps :) I'll post my progress as I move along.......
