bonitarob42
#1 Posted : 15 years ago
bonitarob42
GE Profile Refrig has stopped cooling. Purchased June 2007. Temp Contol unit appears off but if I press pads display comes on with very negative numbers; then displays goes off after a few minutes. There is also a repetitive clicking noise. Anyone know what's wrong?
applianceman
#2 Posted : 15 years ago
applianceman
Pull the refrigerator out and remove the cover off the main board (# 801 on your parts breakdown). If the clicking noise is coming from the board the board is bad. For more on this visit GE Refrigerator Repair Guide
bonitarob42
#3 Posted : 15 years ago
bonitarob42
Thanks Applianceman -- that's where the noise is coming from. Now hopefully, this board is covered by the GE "silent recall" I'm reading about in other threads. Much appreciated!
applianceman
#4 Posted : 15 years ago
applianceman
It is funny you call it a "silent recall" because I work for a GE dealer/GE independent service company and we didn’t even know anything about the extended coverage GE was giving on those boards. I actually learned about it on this forum. What good is the coverage if they aren’t going to let their dealers know about it?
Hope it works out for you!
bonitarob42
#5 Posted : 15 years ago
bonitarob42
Apparently, the "silent recall" is only on certain models for the same part #. What a bunch of "you know what". When the factory authorized repairman comes to the home, they type in the model & serial #s in their computers and it comes up with the msg. if covered. Mine wasn't; even though its less than 3-yrs old, which is the extended warranty on this part for other models. I complained to the repairman, and he called customer service. They ended up covering the part but it still cost me $175 for the call plus labor. At least this site saved me the $195 part cost. Should have probably done it myself, but I was concerned about maintaining the 5 yr warranty on the compressor, et al. Thanks, again!
