demortis1968
#1 Posted : Friday, October 16, 2009 4:29:27 PM(UTC)
demortis1968
My dishwasher quit working during a cycle. I don't get any lights on the display. The dishwasher is dead. There is electric getting to the unit. Please help.
Thank you.
#2 Posted : Friday, October 16, 2009 5:39:28 PM(UTC)
Replacement parts for WHIRLPOOL GU1200XTLS3 | AppliancePartsPros.com
See Item 6 in the "Control panel" section
demortis1968
#3 Posted : Friday, October 16, 2009 8:28:46 PM(UTC)
demortis1968
Originally Posted by: denman Go to Quoted Post
Denman,
Thank you very much for replying. I thought is was the fuse too but the fuse is good. I used my multi-meter and the fuse is NOT open. I also check both door close micro switches and they test good also. What else do you think it could be?? Any help is very much appricieated.
demortis1968
#4 Posted : Saturday, October 17, 2009 3:36:48 AM(UTC)
This may help
https://secured.whirlpoo...520548/$FILE/8178022.pdf
Only a couple things:
1. Did you remove the fuse from the unit when you measured it? Also did you remove one wire from the switch? Please do not take offence but many people do not do this and they measure an alternate/parallel circuit path and it really confuses things.
2. Did you measure voltage at/on the board. A couple months ago I had a number of units where the wire nut connections were no good.
If you get power to the board and it does not fire up then the only thing I can think of is that the board is toast.
demortis1968
#5 Posted : Saturday, October 17, 2009 1:27:26 PM(UTC)
demortis1968
Denman,
Thanks again for the help. I did everything you said I should do. Now I need to make sure I am getting power to the board. Where should I place my voltmeter on the board to measure power to the board and what voltage should I be seeing?
Once again...thank you much.
demortis1968
#6 Posted : Saturday, October 17, 2009 2:20:19 PM(UTC)
I cannot make out the actual pin locations on the diagram but they are the W wire (lower right on the board in the diagram) as a common and then the line from the fuse and from the switch (switch closed) (both at top of board in the diagram). Both should give 120 volts
