mikeeagle22
#1 Posted : Thursday, October 15, 2009 6:08:06 AM(UTC)
mikeeagle22
My washer is doing everything it should except on the spin cycle it will sometimes not work. When that happens I either have to spin it by hand to get it started or have to lift up on the drum and shake it then it will spin properly any idea what may be the problem.
sidfink43
#2 Posted : Friday, October 16, 2009 5:41:54 AM(UTC)
sidfink43
In many case this kit will fix the problem.
Part number: 12002213
heath6357
#3 Posted : Thursday, April 26, 2012 7:27:37 AM(UTC)
heath6357
What is that part and what does it do?
sidfink43
#4 Posted : Thursday, April 26, 2012 9:46:15 AM(UTC)
sidfink43
This is a thrust washer kit for a Maytag built washer. It makes the machine spin.
Washer not spinning properly (Washer Repair)
by outbackblackjack 12/2/2013 9:02:13 AM(UTC)
Maytag washer not spinning properly (Washer Repair)
by tnglc 11/18/2009 3:41:52 PM(UTC)
