outbackblackjack
#1 Posted : Monday, December 2, 2013 9:02:13 AM(UTC)
outbackblackjack
I have a Roper Washer RAX4232KQ0 that isn't spinning clothes completely dry. I replaced the block a week ago thinking that was the problem and it didn't fix the problem. Now I'm guessing the problem might possibly be the coupling or clutch instead. With a full normal load or small load it spins really slowly therefore leaving the clothes overly wet. To further elaborate on the problem with spinning clothes dry it will only spin 1 or 2 articles of clothing at a time dry and not a full load or even a small load. Your advice is greatly appricated.
Thanks,
Steve
fairbank56
#2 Posted : Monday, December 2, 2013 11:30:24 AM(UTC)
fairbank56
Groups: Expert
You most likely need to replace the clutch but I would check the condition of the motor coupler first.
Whirlpool 285785 Clutch Assembly - AppliancePartsPros.com
Whirlpool 285753A Whirlpool Direct Drive Washer Motor Coupling - AppliancePartsPros.com
Eric
outbackblackjack
#3 Posted : Wednesday, December 4, 2013 7:56:15 AM(UTC)
outbackblackjack
fairbank56 Eric I checked the Direct Drive Washer Motor Coupling and the arms & the hockey puck all look like brand new so I am assuming the Clutch Assembly is bad? Is there anyway to check the Clutch Assembly?
Thanks,
Steve
Guest (4)
Maytag washer not spinning properly (Washer Repair)
by tnglc 11/18/2009 3:41:52 PM(UTC)
by mikeeagle22 10/15/2009 6:08:06 AM(UTC)
