My oven will not heat up. The broiler is working fine. I am thinking the ignition switch may need to be changed. Any ideas?
Check if there is 120 VAC to the Bake igniter (#14 on the diagram) while the control calls for Bake. If there is proper voltage then the igniter is the culprit. - The oven igniter Part number: AP4096256
