No heat. Coil did not glow. White spots on coil. And then I broke the coil.:D So I guess have to fix this first and hopefully this was the problem. Can someone point me to the specific one to buy. Do the spots on the element look like the reason why it would not glow? I think I just need the ignitor not the bracket. Photos here: Dryer Ignitor (Maytag Performa) - a set on Flickr
Originally Posted by: thesilverfish ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) No heat. Coil did not glow. White spots on coil. And then I broke the coil.:D So I guess have to fix this first and hopefully this was the problem. Can someone point me to the specific one to buy. Do the spots on the element look like the reason why it would not glow? I think I just need the ignitor not the bracket. Photos here: Dryer Ignitor (Maytag Performa) - a set on Flickr You're definitely going to need a new ignitor. Can't answer for sure about the white spots. If you have a volt meter you can see if you're getting 120 volts at the connector where the ignitor plugs in. If you are then the old one was bad and the new one will fix it for you. If you're not getting power to the ignitor then we're going to have to start back tracking. Part number: AP4038992
Thanks Frank. Ordered.
PS I fixed my Fridge ($50) this spring with your guys help.:)
Originally Posted by: thesilverfish ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks Frank. Ordered.
PS I fixed my Fridge ($50) this spring with your guys help.:) Great! Let us know if the ignitor doesn't solve it.
