Maytag Washer2
#1 Posted : Monday, October 12, 2009 10:38:56 AM(UTC)
Maytag Washer2
Trying to repair my maytag washer. Have to replace my control panel and have 2 questions:
1.) How is the best way to access the plug module that connects the main wiring harness from the control panel to the washer motor? Do you have pull the top and front of the cabinet off to access this primary plug module.
2.) The 2 grey wires (#47 in wiring diagram) that come from the temp control board and connect on 2 leads above the water valves; does it matter which grey wire is connected to which side of the valve?
#2 Posted : Monday, October 12, 2009 1:15:03 PM(UTC)
Here are the Service manual and its supplement.
Quote:
...does it matter which grey wire is connected to which side of the valve?...
No, it does not.
Here are the breakdown diagrams and Replacement parts for MAYTAG MAV7057AWW | AppliancePartsPros.com
maytag washer repair (Washer Repair)
by monty310 1/5/2013 7:34:24 AM(UTC)
Maytag Washer repair (Washer Repair)
by feevbee 8/4/2011 9:13:49 AM(UTC)
Maytag washer repair (Washer Repair)
by lisadominguez 2/14/2011 5:56:52 AM(UTC)
Maytag Washer Repair (Washer Repair)
by indianjoe 12/9/2010 4:16:38 PM(UTC)
Maytag washer repair/part (Washer Repair)
by johntooth 10/18/2010 2:07:14 PM(UTC)
by demeester9 7/28/2010 12:52:51 PM(UTC)
Maytag Washer Repair Manual (Washer Repair)
by pcrouse 12/22/2009 6:12:59 PM(UTC)
by parrisk 6/4/2009 2:45:39 PM(UTC)
