dsudduth
#1 Posted : Thursday, October 8, 2009 6:43:46 AM(UTC)
dsudduth
Hello pros, I have a question about my Frigidaire side by side refrigerator. I have noticed recently that the evaporator fan motor in the freezer section pulses on and off when it is trying to start. It will do this for 5 minutes or so, then it will start operating normally. The air damper control to the refrigerator side also pulses in time with the evaporator fan. I have read that there is a known problem with the evaporator fans in this model, and that possibly the fan is bad and about to fail. I have also read that the contacts may be bad in the air damper control and it needs to be replaced. However, I don't want to replace them if only one is bad, and I was also wondering if it may not be a separate problem since they pulse at the same time...maybe a power supply problem or a switch that supplies power to both the air damper control and fan motor? Any help you guys can provide would be GREAT!!! Thanks!
#2 Posted : Thursday, October 8, 2009 8:14:22 PM(UTC)
In my opinion most likely the problem is a bad adaptive defrost control (#23 on the diagram) because it supplies power for both the fan motor and the damper control motor.
- The adaptive defrost control Part number: AP3562972
#3 Posted : Friday, October 9, 2009 8:10:51 AM(UTC)
I would check the air return behind the fridg. crisper drawer, might have an ice clog.
dsudduth
#4 Posted : Friday, October 9, 2009 9:37:38 AM(UTC)
dsudduth
Thanks, guys! I checked behind the crisper drawer, and didn't find ice or anything else obstructing air flow. I think Gene may be right to try replacing the adaptive defrost, so I ordered one from this site. I'll let you know how that works.
Thanks again!
