jshoe01
#1 Posted : Thursday, January 31, 2008 6:08:47 PM(UTC)
jshoe01
Kemore Elite 25 Cf Side by Side :
The ice maker water line on the fridge side of the inlet valve "sprung" loose and a flooded house was the result. After clean-up i found that the plastic line seemed to be "pulled" (or pushed) out of the compression fitting.
I re-inserted it and tightened the fitting well.
My questions :
1) Is this a common problem ? or a fluke ? Could it wiggle itself out
over time with the on/off vibration/jolt of the valve ?
2) Is this likely to happen again ? Is there a better way to make sure
the house doesn't flood again.
Thanks, jeff
misterfixall
#2 Posted : Thursday, January 31, 2008 6:30:18 PM(UTC)
misterfixall
it could happen again, perhaps you should purchase a new valve. and cut the plastic tube back a bit
jshoe01
#3 Posted : Thursday, January 31, 2008 6:34:22 PM(UTC)
jshoe01
Thanks for the quick reply...
How will a new valve help ?
Do you suggest cutting the tube to make a "fresh" piece ?
jeff
misterfixall
#4 Posted : Thursday, January 31, 2008 6:41:24 PM(UTC)
misterfixall
perhaps the compression fitting is weak ,cut back an inch or so on tube
Guest (4)
