bookerfam
#1 Posted : Tuesday, October 6, 2009 7:02:51 AM(UTC)
bookerfam
I have a RCA Dryer...When attempting to start (turning the start button); it makes a humming sound (like a car trying to start) and then it dies....the best way to describe is like trying to start a car (the car makes a sound likes it's about to start, but then the battery dies and the car doesnt make a sound)
SublimeMasterJW
#2 Posted : Tuesday, October 6, 2009 8:07:55 AM(UTC)
SublimeMasterJW
Reach inside and try to turn the drum. Is it hard to turn? Their may be some things that need to be inspected and replaced to get that baby all propah:
Unplug the dryer and remove it to the yard if possible. Start here:
UserPostedImage
Start here
UserPostedImage
Older models need to have this clip removed(yer we3x75 goes there)
UserPostedImage
we3x75 drum bearing
Remove the screws:
UserPostedImage
Lift the front out yer way
UserPostedImage
Bad drum glides make weird noises sorta like bad rear brake shoes on a garbage truck or bus
UserPostedImage
Old style drum glide
UserPostedImage
Inside the dryer:
UserPostedImage
Note location of non-resetible limit (if bad dryer will not run)
A broken heating element:
UserPostedImage
Broken dryer element (can easily be restrung)No need to buy the whole new pan!
UserPostedImage
A good look at how dat belt oughta be if installed all propah.
