joshmckay
#1 Posted : Monday, October 5, 2009 5:07:16 PM(UTC)
joshmckay
Is there any trick to getting the bottom spray arm back on? I removed it remove a blockage, and can't get it to catch when attempting to screw it back on. The threads look fine. Thanks for your help.
mcbusiness2@mac.com
#2 Posted : Saturday, November 21, 2009 6:00:44 PM(UTC)
mcbusiness2@mac.com
Hey.
I have the same problem. I'm going crazy trying to get this sprayer arm put back together. Did you fix yours? If so how? Thanks!
joshmckay
#3 Posted : Sunday, November 22, 2009 6:03:57 AM(UTC)
joshmckay
I finally got it to catch by thinning down and twisting up the plastic thread on the base screw, using a screwdriver, to make it easier for the nut on the spray arm to catch. It still took a bunch of tries, but it finally worked.
Good luck.
