Is there any trick to getting the bottom spray arm back on? I removed it remove a blockage, and can't get it to catch when attempting to screw it back on. The threads look fine. Thanks for your help.
Hey.
I have the same problem. I'm going crazy trying to get this sprayer arm put back together. Did you fix yours? If so how? Thanks!
I finally got it to catch by thinning down and twisting up the plastic thread on the base screw, using a screwdriver, to make it easier for the nut on the spray arm to catch. It still took a bunch of tries, but it finally worked.
Good luck.
