farina
#1 Posted : Wednesday, September 19, 2007 12:05:21 PM(UTC)
farina
For about the last year in the middle of a cycle the machine starts beeping and flashing code F11. At First I could get it to start again by pressing pause and then start again but for the past two weeks it wont start at all. Any suggestions without having to replace the mcu and interface.
Matt / APP Team
#2 Posted : Wednesday, September 19, 2007 3:42:09 PM(UTC)
Matt / APP Team
Rank: Administration
Groups: Administrators
F11 Serial communication error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.
This is what the code list gives. Open the top of the machine and see if you can find the wiring diagram/troubleshooting guide. Run the tests and look for any loose or bad connections. When you determine what part it is just let us know and we will get you the price and availability.
2600tech
#3 Posted : Wednesday, January 30, 2008 5:24:49 PM(UTC)
2600tech
I removed the CCU and tapped all the relays. And cleaned the solder points on the back of the board with new solder. Took connectors "small" and bent the pins in very very slightly with a pick. Put it back together worked fine. Until six months later the motor went out and sent a charge up the MCU blowing up the capacitors. And burning a resistor in the CCU. Biggest most expensive hunk of junk I own.
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
Whirlpool washer noise for new washer (yes under warranty) (Washer Repair)
by Huntersdl 4/30/2024 3:01:43 PM(UTC)
whirlpool washer model WFW6620HW2 Fried? (Washer Repair)
by justme56 2/11/2024 8:42:17 AM(UTC)
Whirlpool washer F20 code (Washer Repair)
by wstrick14 1/6/2024 3:42:34 PM(UTC)
Whirlpool washer clicking when filling (Washer Repair)
by RogeM 12/3/2023 8:13:49 AM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
whirlpool washer buzzer Way too loud! (Washer Repair)
by Guest 5/1/2023 11:33:43 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Whirlpool washer spins during drain cycle (Washer Repair)
by jsdscot 1/23/2023 5:04:07 PM(UTC)
Whirlpool Washer WTW5105HW1- Loud Spin Cycle- Spring/suspension question (Washer Repair)
by gabeTBP 1/21/2023 6:26:31 AM(UTC)
No Hot Water in Whirlpool Washer (Washer Repair)
by Billpa2023 1/4/2023 12:12:44 PM(UTC)
whirlpool washer fill and drain only (Washer Repair)
by Randero 10/14/2022 2:53:13 AM(UTC)
Capacitor for Front Load Whirlpool washer Model # wfw9550ww00 (Washer Repair)
by Guest 9/11/2022 2:49:05 PM(UTC)
