Hi, my washer, God bless it has been running for quite some time, and all of a sudden it won't spin, however I do hear the motor whirling around and I took the front cabinet off to find that the washer doesn't have a belt, i'm wondering if a gear sheared or maybe the clutch went bad, however I'm not sure how to get inside it to take a peak. any ideas mike
Thanks, I found shaved white plastic at the bottom of the washer and clear plastic tube with a what looked like a nail inside on the ground right below the motor any idea what gear that might of been??
Thanks, I found shaved white plastic at the bottom of the washer and clear plastic tube with a what looked like a nail inside on the ground right below the motor any idea what gear that might of been?? Model # kitchen aid kawe560wwh1
