dick2256@hotmail.com
#1 Posted : Sunday, October 4, 2009 5:32:39 AM(UTC)
All runs but won't heat
I found the rectifier diode coming off of the hv capacitor
open would that keep it from heating up or do I need to search some more
cap checks ok.
Dick2256
ApplianceJunk
#2 Posted : Sunday, October 4, 2009 8:11:37 AM(UTC)
ApplianceJunk
Sounds like a bad diode.
If you have a ohm meter make sure the magnetron is not shorted out to ground before you replace the diode.
#3 Posted : Sunday, October 4, 2009 10:15:47 AM(UTC)
I tried anpother diode from another machine that was about the same physical size and it didn't help
I also tried another magnetron that wasn't the same number and it would start but then would shut down
