curtisn
#1 Posted : 16 years ago
curtisn
My gas oven stopped working the other day after working fine. I called a repair person and he wanted big bucks to repair $$$ (more then the oven is worth). He said it needed both a timer (i assume a control bd) and a oven sensor. Does this sound right? The control board seems to work, burners will not come on.
Is there any way I can test the existing parts to run out why it will not heat up?
Thanks in advance
SublimeMasterJW
#2 Posted : 16 years ago
SublimeMasterJW
ApplianceJunk
#3 Posted : 16 years ago
ApplianceJunk
What burners do not come on?
Bake, broil, top burners?
curtisn
#4 Posted : 16 years ago
curtisn
Top side of range works-only ovens does not work. All indicators come on - on control panel to indicate it is working correctly. However, it never heats up ---this is a GAS range not an electric range
SublimeMasterJW
#5 Posted : 16 years ago
SublimeMasterJW
Everything in the circuit must have continuity for the oven to fire up. What if the ignitor glows but the oven will still not come on? If the ignitor is glowing that would mean you have a circuit. Solution: Replace the ignitor, even if it comes on. Why? Because 99% of the time the ignitor is weak. When it is working fine it should be so bright you cannot look at it for long. If it is a mellow orange color it is bad, replace it. The only way the gas oven valve
would be bad is if it is open and has no continuity. That goes for the control as well.
Check out this simple diagram of how a basic gas range operates.
UserPostedImage
oven ignitor
An ignitor must draw at least 3.5 amps or that safety valve will not open up and release the gas:
. Click on image to see it in motion
A typical late model gas range manua
l
curtisn
#6 Posted : 15 years ago
curtisn
I replaced the control assembly and oven started working correctly-so I guess it was worth paiding the tech for the service call he was right on the money
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest about a year ago
GE gas oven not heating (Oven Repair (including Ranges and Cooktops))
by 1alembic 7 years ago
Gas Oven not heating correctly (Oven Repair (including Ranges and Cooktops))
by Malumake 11 years ago
by csulzbach 12 years ago
GE Gas Oven not heating up correctly (Oven Repair (including Ranges and Cooktops))
by ichengsd 13 years ago
Gas Oven not Heating at all burners OK (Oven Repair (including Ranges and Cooktops))
by tattell 13 years ago
Amana ARGS7650 Gas Oven not heating (Oven Repair (including Ranges and Cooktops))
by reg71 14 years ago
Please Help!! Whirlpool gas oven not heating correctly (Oven Repair (including Ranges and Cooktops))
by Rebetimm 15 years ago
Gas oven not heating properly (Oven Repair (including Ranges and Cooktops))
by wandanyb 15 years ago
Gas oven not heating at all! (Oven Repair (including Ranges and Cooktops))
by krakka 17 years ago
Older Gas Oven not heating up enough (Oven Repair (including Ranges and Cooktops))
by Meg70 17 years ago
gas oven not heating up like it should (Oven Repair (including Ranges and Cooktops))
by fillhardfarm 17 years ago
Gas Oven Not Heating (Oven Repair (including Ranges and Cooktops))
by defirechief8915 17 years ago
