I am trying to take apart the top to get to the indicator light that stays on all the time even when burner is off. I can't find a diagram for this model. It has numbers 0-6 after the main model number. Can anyone give me directions on how to get the top off of the range?
Which light stays "on": the hot surface indicator light or the burner "on-off" indicator light?
The model number you posted is incomplete. There should be one more letter as well as one more digit.
hot surface ind light, it is RF396pxyw3 we replaced the burner switch when the old one went out it smoked and popped and then the light stayed on ever since
Was the switch you used the exactamundo or a replacement equivilent? You have to pay attention to that or if you wire it wrong when 2 burners are switched on that puppy will smoke. Burner Switch Movie (quicktime player)
