My dishwasher runs, sprays water around, but in the end the dirty water is sitting in the bottom. I don't believe is drained out the wash water before going into rinse cycle. Where do I start?
take off the lower wash arm & clean inside when you done try it ;if wont drain so you have to replace the drain pump
My Bosch dishwasher does not drain after wash cycle. I think its the drain pump.How hard is this job? Model no. is shu43c02uc.Could it be something else wrong?
you have to clean inside the d/w by taking the filter & 2 screws under the filter clean this area & try it if wont work you have to replace the drain pump
