lumstruck
#1 Posted : Sunday, January 27, 2008 3:08:49 PM(UTC)
lumstruck
First there was no spin. I found a relay that was locked (like when you open the door at end of spin cycle) so I pulled it back with a plastic tie and it spun like normal. Figured I needed another relay but had to do some wash so I loaded it up and with the relay pulled back, it didn't wash properly so I took the tie off and it washed like normal. I manually put it into the spin cycle so I could monitor what was going on and then nothing but a hum. If I pull the relay back, nothing...if I let the relay go, nothing AND now, it won't wash either. All it does is hum like it does between cycles and if I let go on an hum, after about a minute, I suppose a breaker trips in the motor or something and the hum goes away. I let it sit a hour and then tried again...the hum is back but there is no agitation or spin attempted. Any ideas?? Thanks.
#2 Posted : Monday, January 28, 2008 11:29:31 AM(UTC)
Sounds like the motor gone bad.
The model number you posted is incorrect or just too old - it does not come up.
Verify and repost it, please.
lumstruck
#3 Posted : Wednesday, January 30, 2008 5:04:52 AM(UTC)
lumstruck
yep, the model is correct and is probably over 15 years old...don't really know, it came with the house I bought over 12 years ago.
The hum is not in the motor but in the selector nob that I suppose sends power to the motor. could the relay that I tied up have crashed the controler knob assembly??
