lfisher
#1 Posted : Saturday, September 26, 2009 7:43:16 AM(UTC)
lfisher
My dishwasher fills up but wont spray water to clean the dishes please help
#2 Posted : Sunday, September 27, 2009 2:52:14 AM(UTC)
Could not find info on a SF4 so the following is for a SF2.
Hopefully any changes they have made will be minor.
Here are the parts
Motor & pump replacement parts for TAP TDB210RFS2 | AppliancePartsPros.com
Here is a wiring diagram/tech sheet.
http://manuals.frigidaire.com/p...df/Kinston/154441201.pdf
Remove power from the unit, unplug the motor and check that it has continuity OR measure across it to see if it is getting 120 volts when it should.
An open winding or if it does not run when receiving voltage indicate a bad motor.
If no voltage, unplug the unit, set the timer to where it should be washing and measure from 8T to 2C (power in contacts) if closed (0 ohms) measure from 8T to 2T (Motor contacts), this also should be closed.
Touch panel not lighting and no washing (Dishwasher Repair)
by BogeyBob 11/22/2013 10:05:54 AM(UTC)
buttons light with door open or closed no washing (Dishwasher Repair)
by JERSHAP 4/7/2011 9:41:09 AM(UTC)
Whirlpool Dishwasher Fills then Drains - No washing! (Dishwasher Repair)
by ruplej 11/30/2010 5:53:47 PM(UTC)
No washing pressure (Dishwasher Repair)
by smokinjoe 1/19/2010 12:49:20 PM(UTC)
