tater
#1 Posted : Monday, January 28, 2008 4:59:40 AM(UTC)
tater
Groups ready for retrieval: Registered
Machine works fine except for the loud jet noise in spin cycle.
#2 Posted : Monday, January 28, 2008 12:49:05 PM(UTC)
You have been a member since:: 7/19/2007(UTC)
Check the drain pump for a foreign objects inside.
If there is nothing wrong then, most likely the problem is the transmission/breaks assembly.
- The part number for the drain pump is AP3193205
-The part number for the transmission/break assembly is AP2046402
Jennie Ortega
#3 Posted : Tuesday, March 4, 2008 2:49:12 PM(UTC)
Jennie Ortega
my washer is loud during the spin cycle but also the tub seems to be moving all around, did this happen to your washer as well?
#4 Posted : Tuesday, March 4, 2008 2:57:15 PM(UTC)
Hi Jennie,
What is the complete model number of the washer?
Post it as a new thread, please.
Jennie Ortega
#5 Posted : Tuesday, March 4, 2008 3:22:27 PM(UTC)
Jennie Ortega
Im not sure if this is where the new thread goes but model number is lsq8243hqo
#6 Posted : Tuesday, March 4, 2008 3:53:30 PM(UTC)
The first thing I would do is remove the washer cabinet, remove the drain pump and check for a foreign objects inside the pump. Also check for a foreign objects between the inner and the outer tubs.
Check the suspension parts.
Here are the break down diagrams for the Whirlpool washer Model LSQ8243HQ0
Alan Kosanke
#7 Posted : Monday, March 24, 2008 3:21:25 PM(UTC)
Alan Kosanke
UserPostedImageYes it does.
Alan
bambiblaster
#8 Posted : Monday, March 24, 2008 4:57:46 PM(UTC)
bambiblaster
To both... If these are new machines like within a year the spanner nuts have been coming loose on them and the basket itself is just flopping around in it.. Will need new spanner nuts and lock ring... and depending on ho long it ran a new basket
