plumber75
#1 Posted : Sunday, January 27, 2008 1:31:28 PM(UTC)
plumber75
I have a dishwasher that emits a loud high pitch in the wash and drain cycle. Sometimes its all the time and sometimes it is intermittant. What can we do short of replacint the machine. It is about 12 months old. Kenmore Mod #665.16032403
#2 Posted : Monday, January 28, 2008 9:39:29 AM(UTC)
The first thing I would do is check for a foreign objects in the pump.
Remove the water feeding tube on the back of the dishwasher.
Remove the pump cover and the inlet cover and check the chopper.
plumber75
#3 Posted : Tuesday, January 29, 2008 9:51:18 AM(UTC)
plumber75
Gene: I had already checked the drain but due to your suggestion, looked again. Found a piece of toothpick. Thanks a lot. Plumber75
#4 Posted : Tuesday, January 29, 2008 9:57:50 AM(UTC)
I'm glad you were able to fix it.
kenmore dishwasher 66513043K116 still not draining, after changing drain motor? (Dishwasher Repair)
by thivakaran 12/5/2022 11:47:06 AM(UTC)
Repeating Error 24 on Kenmore Dishwasher (Dishwasher Repair)
by abidh2 12/24/2021 4:45:12 PM(UTC)
Kenmore Dishwasher 665.13733K600 Major Leak Problem (Dishwasher Repair)
by Ken More73 11/10/2021 12:22:29 PM(UTC)
Kenmore Dishwasher - no control lights but washer works (Dishwasher Repair)
by toibn46 10/22/2021 10:08:47 AM(UTC)
Kenmore Dishwasher Keeps Running (Dishwasher Repair)
by VicRattlehead 9/21/2021 1:25:13 PM(UTC)
my Kenmore Dishwasher wont start (Dishwasher Repair)
by Guest 6/14/2021 8:14:07 AM(UTC)
Kenmore dishwasher turning on by itself (Dishwasher Repair)
by Guest 5/24/2021 11:06:12 AM(UTC)
Kenmore Dishwasher drain output has stong sulphur smell (Dishwasher Repair)
by Larbo 1/13/2021 3:35:42 PM(UTC)
Kenmore Dishwasher Heater (Dishwasher Repair)
by mikedbom 11/11/2020 4:21:33 PM(UTC)
Kenmore Dishwasher Smartwash (Dishwasher Repair)
by katzman299 1/4/2020 11:02:06 AM(UTC)
Kenmore dishwasher model 665.15113K211 started high pitch sound between cycles (Dishwasher Repair)
by redeyedog 5/10/2019 8:21:48 AM(UTC)
Kenmore Dishwasher control pannel not working (Dishwasher Repair)
by Douglas Scherer 3/14/2019 6:32:33 PM(UTC)
Kenmore Dishwasher fills then drains (Dishwasher Repair)
by qkantaris 1/5/2019 8:39:01 PM(UTC)
How do you install Part W11048936 for a Kenmore Dishwasher (Dishwasher Repair)
by S Hall 3/23/2018 4:46:54 PM(UTC)
Can't loosen impeller part for kenmore dishwasher (Dishwasher Repair)
by rbhall52 9/5/2017 12:04:52 PM(UTC)
