paulla
#1 Posted : Wednesday, September 23, 2009 3:40:50 PM(UTC)
paulla
my heat stays on all the time even in the air dry cycle I have changed the element all thermostats and the heat fuse because it burnt out at the start of this problem. I have checked the element and it is not grounding out. I am thinking it is the timer am I leaning in the right direction? Any help is greatly appreciated.
#2 Posted : Wednesday, September 23, 2009 7:07:35 PM(UTC)
Here is your wiring diagram
http://www.servicematters.com/d...0Sheet%20-%208528189.pdf
Yes it could be the timer
Unplug the unit
Set the timer to air only
Remove the R wire from the timer and check BK/R contacts
Should be open in air only.
The above assumes that the heat is being regulated but it is on all the time.
glen65
#3 Posted : Wednesday, September 23, 2009 7:08:34 PM(UTC)
glen65
