black05pony
#1 Posted : Wednesday, September 23, 2009 5:16:44 PM(UTC)
black05pony
my washing machine has just started throwing the error code le which the manual states is the water temp. sensor. i took off the bottom panel to check the wires and found the sensor but everything appears fine. i cannot find this part to try and fix my machine. also now the electronic control panel seems to be acting weird as in doesn't make the beeping noise as loud as it once did or sometimes it just clicks. any help with this subject would be greatly appreciated
sidfink43
#2 Posted : Friday, September 25, 2009 5:57:48 AM(UTC)
sidfink43
Here is the service manual for your machine which will show in detail how to test the sensor and how to perform other troubleshooting tasks.
https://secured.whirlpoo...amsug_Neptune_Washer.pdf
Good luck.
