Hi all
i have a kenmore 8318015(this could be wrong only one i could find still looking) i have been looking through the previous posts and right now i'm at the stage where i have the motor sat on the floor only connected to the power ok it will spin anti clockwise (washing) but then it will not go clockwise it tries to and i can spin it by hand and yes you do get the burning smell. thanks for any help
Bluestorm
ps with the motor sitting on the floor is it possible to check for forward and reverse
thanks again
With the motor connected, and the lid switch by passed put the timer on the spin section and see if the motor spins clockwise.
If it does not, check to see if current is coming to the motor. If it is, or if the motor is hung up it will need to be replaced.
thanks for the reply just wondering if you could point me in the right direction please looking at the connector at the motor i have these colour wires Red , orange , gray , green/yellow , yellow , blue , blue/white ok could you tell me which two wires i should check for anticlockwise motion (as that works) and then which two i should check for forward motion.
thank you..
I don't have the wiring diagrams for the connection to these motor, but if it is not turning and you are getting the burning smell it seems likely the motor is your problem.
If you post the complete model number someone else may be able to help.
not sure if this will help but i have to motor no 8528157 still looking for the rest.. o buy the way i did get a new motor:(
thanks
hi again ok got this other no W10025668 could this be the right one
hi all lets try this Model: 28692701 Serial:CW1030454 hope someone can help thanks in advance..
Hi there just asking if someone can help me out with this part i need to test the motor for both clockwise and anti clockwise motion the motor is disco from the drive i just need to know which wires i need to connect to 120v to see if the motor runs in both directions if i have to motor on the floor looking down at the connection block on top the colour of the wires from left to right are:- Black-Purple-Black/White-Blue-Yellow-White thanks for the help
