bluestorm
#1 Posted : Monday, September 21, 2009 11:03:46 AM(UTC)
bluestorm
Hi all
i have a kenmore 8318015(this could be wrong only one i could find still looking)
i have been looking through the previous posts and right now i'm at the
stage where i have the motor sat on the floor only connected to the power
ok it will spin anti clockwise (washing) but then it will not go clockwise it
tries to and i can spin it by hand and yes you do get the burning smell.
thanks for any help
Bluestorm
ps with the motor sitting on the floor is it possible to check for forward and reverse
thanks again
sidfink43
#2 Posted : Tuesday, September 22, 2009 1:00:56 PM(UTC)
sidfink43
With the motor connected, and the lid switch by passed put the timer on the spin section and see if the motor spins clockwise.
If it does not, check to see if current is coming to the motor. If it is, or if the motor is hung up it will need to be replaced.
bluestorm
#3 Posted : Wednesday, September 23, 2009 4:56:15 AM(UTC)
bluestorm
thanks for the reply
just wondering if you could point me in the right direction please
looking at the connector at the motor i have these colour wires
Red , orange , gray , green/yellow , yellow , blue , blue/white
ok could you tell me which two wires i should check for anticlockwise motion
(as that works) and then which two i should check for forward motion.
thank you..
sidfink43
#4 Posted : Wednesday, September 23, 2009 5:22:07 AM(UTC)
sidfink43
I don't have the wiring diagrams for the connection to these motor, but if it is not turning and you are getting the burning smell it seems likely the motor is your problem.
If you post the complete model number someone else may be able to help.
bluestorm
#5 Posted : Wednesday, September 23, 2009 5:39:39 AM(UTC)
bluestorm
not sure if this will help but i have to motor no 8528157
still looking for the rest.. o buy the way i did get a new motor:(
thanks
hi again ok got this other no W10025668 could this be the right one
bluestorm
#6 Posted : Wednesday, September 23, 2009 12:53:54 PM(UTC)
bluestorm
hi all
lets try this
Model: 28692701
Serial:CW1030454
hope someone can help thanks in advance..
bluestorm
#7 Posted : Saturday, September 26, 2009 8:22:57 AM(UTC)
bluestorm
Hi there
just asking if someone can help me out with this part
i need to test the motor for both clockwise and anti clockwise motion
the motor is disco from the drive i just need to know which wires i need to
connect to 120v to see if the motor runs in both directions
if i have to motor on the floor looking down at the connection block on
top the colour of the wires from left to right are:-
Black-Purple-Black/White-Blue-Yellow-White
thanks for the help
Guest (6)
