Peter687
#1 Posted : Wednesday, September 23, 2009 5:17:08 AM(UTC)
Peter687
Probably a common question, but I did a search on my model number and did not find anything so here goes.
I am getting a loud repetitive squeaking noise when the dryer is running. I am guessing it is a bearing or several bearings. I went to the parts section and there is a bearing kit (Model AP2619300) for my unit.
My questions are:
Is this the likely culprit?
Is it hard to replace?
Is there anything else I should replace while I am in there?
Thank you for your help and advise.
Frank / APP Team
#2 Posted : Wednesday, September 23, 2009 7:21:29 AM(UTC)
Frank / APP Team
My questions are:
That part is notorious for causing what you're describing. The drum will need to be removed in order to install. Not a real hard job if you're somewhat handy. As far as anything else to replace, you'll need to look around while you're in there. Long as you're in there be sure to clean up any lint build ups.
Part number: AP2619300
Peter687
#3 Posted : Thursday, September 24, 2009 4:50:49 AM(UTC)
Peter687
Sorry to be repetitive, but I was wondering if there were any other bearings or guides or belt that I could replace while I had the dryer open.
Thanks.
Frank / APP Team
#4 Posted : Thursday, September 24, 2009 6:02:37 AM(UTC)
Frank / APP Team
Thanks.
Here's some other items. The glides come in two different colors, you'll need to see which color yours are.
Part number: AP3790641
Peter687
#5 Posted : Thursday, September 24, 2009 11:01:49 AM(UTC)
Peter687
Guest (6)
Maytag Atlantis dryer....LOUD squeaking noise (Dryer Repair)
by kimber23ks 10/14/2010 5:38:54 AM(UTC)
Loud Squeaking Noise (Dryer Repair)
by bdmcgal 12/10/2008 3:24:25 PM(UTC)
ge dryer is making loud squeaking noise (Dryer Repair)
by georgepannier@sbcglobal.n 12/26/2007 3:57:00 PM(UTC)
Loud squeaking noise during spin cycle (Washer Repair)
by thwillis99 11/14/2007 8:17:55 PM(UTC)
