2 Pages12>
Grumps
#1 Posted : Monday, September 7, 2009 12:56:17 PM(UTC)
Grumps
Whirlpool side by side. Refrigerator doesn't cool but freezer and ice maker work fine. Small amount of cold air flow into frig. Cooling coils have very little frost. No excess frost anywhere. Any ideas?
Grumps
AIMANNY
#2 Posted : Monday, September 7, 2009 4:19:16 PM(UTC)
AIMANNY
What are the temps in freezer and refg.
Open refg door close freezer door put your hand by the air damber, do you feel air coming thuough the damper.
Then open freezer door put your hand by the air damber. do you feel a diffnce in the air flow.
Grumps
#3 Posted : Monday, September 7, 2009 4:28:38 PM(UTC)
Grumps
Slight air flow increase when freezer door is opened. Temps Freezer -6F
Frig 52F Air entering frig at vent is -14F
Grumps
AIMANNY
#4 Posted : Tuesday, September 22, 2009 4:26:57 PM(UTC)
AIMANNY
7 UserPostedImage
Enlarge Photo
Motor, evaporator fan
Part Number: AP3137520 made by WHIRLPOOL 7 UserPostedImage
Enlarge Photo
tor your evp moMotor, evaporator fan
Part Number: AP3137520 made by WHIRLPOOL your evp motor. check it.
Grumps
#5 Posted : Tuesday, September 22, 2009 5:14:53 PM(UTC)
Grumps
Fan appears to be working fine diffuser doors are closed. Removed diffuser and frig cooled to 36F
Grumps
glen65
#6 Posted : Tuesday, September 22, 2009 5:32:40 PM(UTC)
glen65
The freezer control may not have been keeping the flap open
in the diffuser assembly. I believe they just use a metal rod to
adjust it. You need to make sure that when you turn the
freezer temp control that it actually opens and closes the vent flap.
Grumps
#7 Posted : Tuesday, September 22, 2009 5:43:12 PM(UTC)
Grumps
There is a wire and a metal rod going into the diffuser assy. I thought the rod was to the thermostat. If that is the case, does the wire control the diffuser door? Is the diffuser control on this model electrical or mechanical?
Grumps
glen65
#8 Posted : Tuesday, September 22, 2009 6:14:02 PM(UTC)
glen65
Grumps
Its mechanical,
All the freezer control does is open or close the air flap.
They use the rod to connect the control to the flap.
You just need to make sure that the freezer control
is actually moving the air flap when you operate it.
Ive had cases where something on the control knob
or the diffuser would be broken keeping the control
from actually moving anything when you turn it.
Grumps
#9 Posted : Tuesday, September 22, 2009 6:24:12 PM(UTC)
Grumps
The part that confuses me is the rod is connected to the freezer control and the wire is from the frig temp control.
Grumps
glen65
#10 Posted : Tuesday, September 22, 2009 6:48:43 PM(UTC)
glen65
That's because they only need the electrical control in the frig
to cycle the unit off. Since the air in the frig comes from
the freezer and the frig is only going to cool properly if the
freezer gets down to the right temp anyway then an electrical
control really isn't needed for it.
2 Pages12>
