SupermanRepairman
#1 Posted : 15 years ago
SupermanRepairman
I've replaced the drum bearing system, as well as made sure nothing was touching the barrel as it turned. I put it back together and no change in the sound.
SublimeMasterJW
#2 Posted : 15 years ago
SublimeMasterJW
WE3X75 is the part number of the plastic rear drum support bearing. That is your squeak source.:D
SupermanRepairman
#3 Posted : 15 years ago
SupermanRepairman
I don't think that is it, The squeak only happens when a load is in the dryer. It's also louder when listening to it in the front opposed to the sides or behind it.
#4 Posted : 15 years ago
As SublimeMasterJW said the rear bearing is the most common cause of squeaks in this unit which I believe you said has been replaced.
They can also be caused by the idler roller or motor bearings.
Could even be the front glides.
Often it is difficult to find the cause as sound can travel through the case/frame and be deceiving as to it's source.
I would try a drop of oil on the idler wheel and it's support rod where it attaches to the frame/motor. Use sewing machine or 3in1 oil not wd40 as wd40 in not a very good lubricant.
SupermanRepairman
#5 Posted : 15 years ago
SupermanRepairman
The front glides seem likely. I did notice some areas that just looked worn on the front of the drum when I took it apart. I'll drop some oil or grease on it and see if it helps.
Squeaky Dryer (Dryer Repair)
by luaumaster 12 years ago
by jervisdj 12 years ago
squeaky dryer (Dryer Repair)
by frankn 13 years ago
by lgibson 14 years ago
Repair of squeaky dryer (Dryer Repair)
by sbuckley@dtec.com 14 years ago
very LOUD squeaky dryer (Dryer Repair)
by sdvia 15 years ago
Squeaky dryer: which part(s) do I need (Dryer Repair)
by JerzyL 15 years ago
Kenmore Squeaky Dryer (Dryer Repair)
by RussAwana 15 years ago
Squeaky dryer (Dryer Repair)
by Bill in Mass. 15 years ago
Loud Squeaky Dryer Noise (Dryer Repair)
by Hart1092 15 years ago
by Alanna 15 years ago
by linus410 15 years ago
by Kruldaddy 15 years ago
by fiorillo 16 years ago
by liang 16 years ago
