Model Number DVL223EYOWW is getting so hot it burned the sticker off the back.
I have it apart and believe one of the thermostats are bad. The vents are spotless and airflow is good.
I removed the Hi Limit Thermostat and put an ohm meter on it and it reads 0.000 which tells me its closed and good?????????
The control thermostat which has 4 points checks out with end to end points closed and top to bottom points reads 28 ohm so its open.
Something is causing the heating element to overheat.
What do recommend I do. Change the control stat or both?
Check out the heater element. Remove both wires from it then check it for resistance usually around 10 ohms. Then check each terminal to the case/frame should be infinite (open). In not then you have a grounded element which can cause it to run unregulated. Could be it is broken and touching the case or may have sagged and touching the case.
You can heat up the thermostats on a stove top element to see if they open. Usually you can hear them click and then check them for resistance. If not their internal contacts are welded together. Be careful not to burn yourself. |
THIS FORUM IS DEAD!!!!!!! |
The stat opens when placed on stove top but the ohm meter sits on 1 until the stat close and for brief second, it reads -23.5. What should the ohm read, (set on 20k) when opened? The heating elements is fine.
When it is open it should be infinite. Do not know what type of meter you are using but it should read the same as when the meter leads are not touching each other.
My Fluke just shows 1 on the left hand side and a decimal point. |
I have digital which reads 1 when not touching. I got another high limit switch and they both open and read the same until they close so I assume they are good???
The heating element case does touch the cabinet but I don't see how it could not since it is screwed to the cabinet.
Can I test the control stat the same way and if so, what am I looking for since we have 4 terminals.
When checking the heating element, none are touching the case. The ohm reads 11.7 when disconnected so it seems the element is ok
Sorry about that. The heating elememt itself is not touching the case (which is screwed to the cabinet) When I disconnect the terminal, I get a reading of 11.7 ohms.
If the element is good and the high limit switch is opening, are we down to checking the control stat and if so, how would I do that?
I have digital which reads 1 when not touching. I got another high limit switch and they both open and read the same until they close so I assume they are good??? Yes, they also look good to me also
The heating element case does touch the cabinet but I don't see how it could not since it is screwed to the cabinet. The element should feed through insulators into the case. Note: the element runs off 240 volts(L1 to L2) with all the control thermostats wired is series with it so if it touches the case (Neutral) it can do all sorts of weird and not so wonderful things depending where it touches.
Can I test the control stat the same way and if so, what am I looking for since we have 4 terminals Yes you should be able to. A 4 terminal thermostat is usually 2 terminals for the contacts and two terminals for an internal heater. This heater is turned on for different temp selections, it adds heat to the thermostat causing it to cycle more often, reducing the machines temperature. Usually it measures around 4 or 5 kilohms.
Do not know if you have a wiring diagram, if not take a look inside the control console. They like to put it in there. Getting wiring diagrams for a GE off the web is difficult to say the least. They like to keep that info secret and keep their techs busy. So I cannot be 100% sure about the above as I do not have a wiring diagram. |
when i test the control stat, I have 0.000 on the end to end terminals and 1.0 on the top to bottom which according to the diagram is the heater contact you discribed. When I hear it click, I test both sets and they both read 1.00. When the stat click back or opens the I get the original readings. Should they both be open??
No only the contacts should open but your reading seems to indicate that the contacts are not opening.
Note: I did find a couple GE wiring diagrams that used an internal heater and both of them showed the heater as 9 kilohm. Your readings show that something is haywire with this thermostat. |
