Our Kitchenaid KUDM01TJBS0 that has worked fine for 6+ years, but now none of the lights on the push button keypad display light up, and it simply does nothing. I reset the house circuit breaker, but no change with the dishwasher.
I've read that a ribbon cable is sometimes the culprit, and will take a look at that. I have looked at a few parts diagrams showing the control board and key pad, but I didn't see a ribbon cable. I presume it'll be obvious when I open it up. Anything I should look for or test?
I also noticed the hinger area of the door is rather loose and sloppy. Is there are way to snug this up?
Any suggestions are greatly appreciated!
Last night I opened up the door, cleaned all connections and re-seated all the cables, and tested the relay switch on the handle. There is a white "plug" component (see attached image) marked "MOTORTEMP", that I presume is the thermal fuse. With nothing connected to it, there is no continuity between the two terminals. Does this indicate the unit is defective? If so, do I need to replace just this, or would another component cause it to fail that also needs to be replaced? Any advice on this would be appreciated. cheers, Dave
THIS FORUM IS DEAD!!!!!!! |
Thanks for taking time to reply to my inquiry. The kit description says the wiring harness must also be replaced. The wiring harness on my diswasher appears to be just a bundle of wires, two of which have push on clips for the two terminals on the thermal fuse. Is it OK to just replace just the fuse, or do I need to attach the wires to my wiring harness? The wires in the kit photo look as if they may be designed to attach to a terminal block. I'm not sure if I need them, or how to attach them to the wiring harness. Thanks again for your assistance. cheers, Dave Originally Posted by: denman
I had a problem with this dishwasher back in '09, and had to replace a fuse assembly connected to the control panel.
Today the dishwasher won't run. There is a small LED light next to the Cancel/Drain button that blinks on and off. However, I can't get any of the other buttons to illuminate or do anything. I have cycled the power off and on at the mains fusebox, hoping to reset the dishwasher's control panel, but no such luck. As the dishwasher's LED is lighting up, I presume the unit is getting power. Should I replace this fuse again, or could it be a failure at the control panel? Is there a way to test the fuse with a meter?
I read a post that suggested pressing the HiTemp Scrub and Energy Saver Dry buttons in sequence a few times may reset the controller board. Either I'm not doing it correctly or it isn't resetting the controller board.
Any thoughts on this would be appreciated. I'm somewhat electro-mechanically challenged, but my wife thought I was a total genius when I replaced the fuse last time. It would be great to relive the fleeting moment of grandeur with a simple fix!
cheers y'all
See the attachment for the tech sheet I had a problem with this dishwasher back in '09, and had to replace a fuse assembly connected to the control panel. [COLOR="Blue"] I have cycled the power off and on at the mains fusebox, hoping to reset the dishwasher's control panel, but no such luck. I read a post that suggested pressing the HiTemp Scrub and Energy Saver Dry buttons in sequence a few times may reset the controller board. Either I'm not doing it correctly or it isn't resetting the controller board.[/COLOR] Did you give it a couple minutes with the power off? Removing power from the unit is the best way to reset the board. [COLOR="Blue"]As the dishwasher's LED is lighting up, I presume the unit is getting power. Should I replace this fuse again, or could it be a failure at the control panel? [/COLOR] No as a blown fuse would kill power to the control board and it is getting power. Yes it could be a bad control board, Try running the diagnostics, see the tech sheet. [COLOR="Blue"] Is there a way to test the fuse with a meter?[/COLOR] Yes. Remove either one side or both sides and measure it with a meter, should be 0 ohms. [COLOR="Blue"]Any thoughts on this would be appreciated. I'm somewhat electro-mechanically challenged, but my wife thought I was a total genius when I replaced the fuse last time. It would be great to relive the fleeting moment of grandeur with a simple fix![/COLOR] Could be that the cancel/drain button is shorted, check it with a meter. |
Thanks for taking the time to answer and attaching the diagnostics PDF! Much appreciated!!!
I will disconnect power for a longer period to see if that will reset the controller board. If the fuse checks out, I'm guessing the problem may be a stuck key. In my case, the LED next to the CANCEL/DRAIN key is flashing.
Per the diagnostics sheet: STUCK KEY: If the control detects that a key is stuck in the depressed position, dishwasher operation will be suspended and the control will flash the light for that key until the condition is corrected. If a key without a light is stuck or multiple keys are stuck, the control will flash the light for the Rinse Only/Quick Rinse key.
I disconnected power for over an hour, but the CANCEL/DRAIN button resumed blinking once power was turned back on. As the diagnostic sheet says a blinking light suggests a stuck key, ordering a replacement Console Assembly seems like the thing to do. If that part doesn't fix it, can it be returned in exchange for a new control board?
