Peanut24
#1 Posted : Thursday, September 10, 2009 5:47:28 PM(UTC)
Peanut24
Washer keeps getting off balance and can usually reposition load but problem has gotten worse. Could the suspension springs have gotten weak and need to be replaced? i have check the level of the washer and all is good there?
sidfink43
#2 Posted : Saturday, September 12, 2009 5:15:08 PM(UTC)
sidfink43
Take off the cabinet and inspect the springs, and the pads and make certain the suspension plate is set correctly. Replacing the springs and pads is a good idea.
Off Balance Washer (Washer Repair)
by jenn_luvs_jeff 10/28/2014 6:26:40 PM(UTC)
