evochka
#1 Posted : Monday, January 21, 2008 10:25:52 AM(UTC)
evochka
We've trying to take out heating spiral in the oven,but we didn't unplug the stove and short circuit happened.can we fix it by ourself?
#2 Posted : Tuesday, January 22, 2008 12:16:16 PM(UTC)
Everything is fixable but you have to learn first what has been damaged.
fyxer
#3 Posted : Tuesday, January 22, 2008 1:11:54 PM(UTC)
fyxer
I assume you are talking about an electric stove,and you were trying to take out the--electric spiral-- by this i think you are refering to the oven or burner element,you must have blown a fuse or breaker,older houses carry fuse newer ones use breakers they do the same thing,disconnect the power from the appliance whenever there is a short or a over load,a fuse usually need to be replaced, while a breaker can be reset, be careful electricity can cause property and personal damage it can also kill you.
