gbolen1
#1 Posted : Wednesday, September 9, 2009 9:53:07 AM(UTC)
gbolen1
I have replaced an electric control panel on this unit 2x in the past year. I need to know if there is a part I can order to replace the wiring/harness assembly that is located inside the door, runs from the base of the door to the control panel. The connection that feeds into the control panel (part ordered was #8564546) into the slot W-R is melted on the one side and this may be the cause of the panel shorting out.
#2 Posted : Wednesday, September 9, 2009 2:48:34 PM(UTC)
The main wiring harness Part number: AP3178193
The other way to fix it is to cut off the bad wire terminal with burned part of the wire and install a new terminal.
- The insulated terminals (pack of 15) Part number: AP3440459
gbolen1
#3 Posted : Wednesday, September 9, 2009 4:07:41 PM(UTC)
gbolen1
Thanks Gene, don't know where or how you found that wiring harness part, as I looked and couldn't find it. I like your idea of just replacing the terminal, especially since I believe only the one wire is bad... could I just go to a Lowe's or electric supplies store to purchase a single termninal? What about the housing this bad terminal is encased in, which is partially melted, does that need to be replaced as well, and where would I find such a casing do you think? Really appreciate your help! Thanks again, Greg
#4 Posted : Sunday, September 13, 2009 5:44:46 PM(UTC)
Sorry for the delay. Is this terminal just a single terminal or it is a part of a plug? If it is a part of a plug then I'm afraid you have to buy the whole harness, cut the needed plug of it and splice it instead of the damaged one.
Whirlpool dishwasher repair question (Dishwasher Repair)
by asouth 1/18/2014 12:36:20 PM(UTC)
Whirlpool Dishwasher repair (Dishwasher Repair)
by isaac75739 9/9/2012 2:02:50 PM(UTC)
