Dryer squeaks ( very loud ) when you first turn on the dryer. Slowly fades away as dryer heats up. Do I need a new belt? Help!!!!
We cannot really tell you anything without a complete model number.Our generic answer would be to replace the belt, idler pulley and support wheels (assuming it has them). This is good maintenance even if it does not fix your problem.If you want more info, try to tell where the noise is located and post the model number.Thanks
