delank
#1 Posted : Wednesday, September 2, 2009 8:12:24 AM(UTC)
delank
Our dryer won't turn on when any button is pressed, all leds stay dark. at first I thought it was the door switch because I slammed the door shut then hit a button and the display lit up. so I cancled the cycle and tryed it again and nothing lit up. I checked the door switch with a meter it, tested ok , two position switch continuity ok in and out. also tryed to check thermistors and switches in lower portion of dryer they look ok. Over a period of a couple days I would plug it in and try it sometimes it would start sometimes not. when it did start the end of cycle alarm would sound and the led for end of cycle would change from high to low to off over and over. This morning I tryed it and nothing will turn on. I am thinking its the control board that the panel plugs into but for $ 160.00 dollars and non returnable if it doesn't fix the problem I'm a little hesitant to order.
Can you help, thanks, Ken
#2 Posted : Wednesday, September 2, 2009 11:17:39 AM(UTC)
Quote:
...at first I thought it was the door switch because I slammed the door shut then hit a button and the display lit up...
It can be a sign of a loose connection somewhere. I would start the troubleshooting from this point.
Look for the tech sheet inside the control panel and run the tests recommended by the manufacturer.
What is the complete model number of the dryer?
delank
#3 Posted : Wednesday, September 2, 2009 2:03:34 PM(UTC)
delank
Hi Gene.
I've reseated everything I could find on the control board and in lowerunit of dryer. The only numbers I could find are 050946957081 or D26 M85088 , do those numbers look right? I didn't see a tec sheet any where in the dryer.
#4 Posted : Wednesday, September 2, 2009 5:35:25 PM(UTC)
Check the door frame for the name plate.
delank
#5 Posted : Wednesday, September 2, 2009 5:40:46 PM(UTC)
delank
Mod 110.85088400
#6 Posted : Wednesday, September 2, 2009 5:51:26 PM(UTC)
Perform the troubleshooting as described in the Service manual and the Tech sheet, and post the results.
LG Dryer wont turn on (Dryer Repair)
by stz2 7/28/2021 2:09:54 AM(UTC)
Kenmore Dryer Wont Turn On (Dryer Repair)
by tmurphy12 11/11/2017 5:37:21 PM(UTC)
Dryer wont turn on. Nothing at all (Dryer Repair)
by jim5775 2/7/2013 1:31:10 PM(UTC)
Dryer wont turn on, bulb stays on when door closed (Dryer Repair)
by mazw 7/24/2012 4:21:01 PM(UTC)
Dryer wont turn on, bulb stays lit when door closed (Dryer Repair)
by mazw 7/24/2012 4:13:34 PM(UTC)
by sweetness 6/21/2012 12:24:11 PM(UTC)
admiral dryer wont turn on (Dryer Repair)
by tammy27 6/12/2012 1:08:36 PM(UTC)
by G.A.Russell 2/12/2012 12:42:26 PM(UTC)
by blackcobra427 11/2/2011 9:31:12 AM(UTC)
Roper Dryer wont turn on (Dryer Repair)
by edwardsnl 1/15/2011 12:37:58 PM(UTC)
by snooki 12/2/2010 5:45:01 PM(UTC)
by ritadi 7/4/2010 9:30:53 AM(UTC)
by carri0321 3/29/2010 1:34:12 PM(UTC)
lady kenmore ultra fabric care electric dryer wont turn on (Dryer Repair)
by John414 3/6/2010 7:19:25 AM(UTC)
Frigidaire dryer wont turn on (Dryer Repair)
by gamermom79 1/13/2010 11:15:41 AM(UTC)
