agale2000
#1 Posted : Sunday, January 20, 2008 11:06:43 AM(UTC)
agale2000
I was cooking a roast yesterday in my upper oven and my daughter said she heard a sizzling sound and a small popping noise coming from the oven. When I returned home and checked it 20 minutes later, the roast was somewhat cool to the touch. The oven was no longer heating up. Is it possible that the element went out? If so, can I repair it myself by ordering an element? Thank you for your help.
kawfeeman
#2 Posted : Sunday, January 20, 2008 11:14:53 AM(UTC)
kawfeeman
what cooking program were you using ? Were you using convection or standard conventional bake ? whatever program you were using, try using the other program.. Also, see if broil works ?
agale2000
#3 Posted : Monday, March 3, 2008 8:48:40 AM(UTC)
agale2000
I tried the broiler and it works. The convectional and regular baking does not work. I appreciate your help.
Frigidaire - Oven will not heat up but burners work (Oven Repair (including Ranges and Cooktops))
by JohnGuerra 3/18/2020 12:45:12 PM(UTC)
Frigidaire gas oven will not heat (Oven Repair (including Ranges and Cooktops))
by HHG 9/6/2019 11:33:44 AM(UTC)
GE Profile Oven will not heat past 100, broiler works (Oven Repair (including Ranges and Cooktops))
by maribernj 2/16/2016 8:37:13 AM(UTC)
Oven will not heat (Oven Repair (including Ranges and Cooktops))
by couldcareless 11/11/2015 2:05:29 PM(UTC)
by davidwhop 8/31/2014 7:17:47 AM(UTC)
Double Wall Oven will not heat up (Oven Repair (including Ranges and Cooktops))
by jwmingus 11/12/2013 4:25:40 PM(UTC)
Frigidaire Left oven will not heat either element (Oven Repair (including Ranges and Cooktops))
by morang 9/27/2013 5:08:44 PM(UTC)
Thermador sc302t top oven will not heat (Oven Repair (including Ranges and Cooktops))
by bnastasi 6/9/2013 9:01:10 PM(UTC)
Lower and Upper Oven will not heat (Oven Repair (including Ranges and Cooktops))
by Igmike 4/22/2013 5:43:12 AM(UTC)
My Oven will not heat up on bake (Oven Repair (including Ranges and Cooktops))
by missy79 4/3/2013 9:59:06 AM(UTC)
Electrolux dual fuel range oven will not heat (Oven Repair (including Ranges and Cooktops))
by p.andrew 3/19/2013 8:47:44 AM(UTC)
by Pjcibulski 1/29/2013 2:00:44 PM(UTC)
Oven Will Not Heat (Oven Repair (including Ranges and Cooktops))
by badams1214 1/18/2013 12:14:24 PM(UTC)
Maytag Oven Will Not Heat Up (Oven Repair (including Ranges and Cooktops))
by debost 1/16/2013 9:46:49 AM(UTC)
by AZWY35 12/9/2012 3:50:17 PM(UTC)
