Agawam
#1 Posted : Monday, August 24, 2009 9:30:14 AM(UTC)
Agawam
The ice dispenser hinged door doesn't close properly. How can it be replaced?
#2 Posted : Monday, August 24, 2009 12:04:19 PM(UTC)
You can use the instructions attached to one of our previous posts: http://forum.appliancepartspros...ctrical-malfunction.html
Here are the breakdown diagrams and Replacement parts for GE GSS25WGMDWW | AppliancePartsPros.com
Agawam
#3 Posted : Tuesday, August 25, 2009 1:03:53 PM(UTC)
Agawam
Thanks for the information. Some progress has been made. However, I find that the ice disposer flapper will not close reliably. A cube or piece of ice remains in the outlet of the hopper preventing the flapper from closing. Consequently warm air enters through the flapper opening and that results in melting of ice in the hopper and total non-operation of the ice dispenser. Do your think the spring for the flapper has lost sufficient tension or is there another reason for the ice remaining in the hopper outlet? When the hopper is empty, the flapper closes every time.
#4 Posted : Thursday, August 27, 2009 8:52:49 PM(UTC)
I would take it apart and check all parts involved.
Agawam
#5 Posted : Monday, August 31, 2009 9:45:10 AM(UTC)
Agawam
Gene,
Thank you. I checked the parts and found the solenoid armature badly corroded. It appears that could be the source of the problem.
#6 Posted : Monday, August 31, 2009 4:43:35 PM(UTC)
Quote:
...It appears that could be the source of the problem...
It is very possible. Keep us posted.
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Whirpool WRF535SMBM Refrigerator (Refrigerator & Freezer Repair)
by goclones 6/16/2024 8:15:11 AM(UTC)
Samsung Refrigerator Pantry Drawer Support #SAM-DA61-03174A (Refrigerator & Freezer Repair)
by joecoliphant 6/15/2024 8:12:03 AM(UTC)
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
LG Refrigerator - Makes ice, but won't dispense ice nor water (Refrigerator & Freezer Repair)
by teamfindley 5/28/2024 7:48:32 PM(UTC)
samsung fd refrigerator (Appliance Repair Companies - East of the Mississip)
by gale reid 5/28/2024 3:17:33 PM(UTC)
Cold-Coldest setting on meat drawer on GE GNE25j refrigerator (Refrigerator & Freezer Repair)
by Guest 5/23/2024 11:20:53 AM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Refrigerator Ice (Refrigerator & Freezer Repair)
by Guest 5/9/2024 7:00:37 AM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
