CharlieIn
#1 Posted : Sunday, August 30, 2009 6:05:50 PM(UTC)
CharlieIn
Hello,
We have an a Whirlpool Super Capacity 465 (Model RF370LXGN) electric range. Recently, the left front burner has gotten excessively hot more than once. Yesterday the control was set to 3 and nearly caused a fire because the entire element was uncharacteristically bright red (so much for the chicken!)
Would the control knob be the problem, or is there any other thermostat?
:cool:
#2 Posted : Monday, August 31, 2009 11:14:36 AM(UTC)
Most likely the problem is a bad infinite switch for this burner.
- The switch Part number: AP3095444
CharlieIn
#3 Posted : Thursday, September 3, 2009 7:44:28 AM(UTC)
CharlieIn
Thanks Gene. You said 'most likely' the problem is the infinite switch. Is there any test to be certain?
Thank you for your assistance.
axrowland
#4 Posted : Thursday, December 17, 2009 12:40:56 PM(UTC)
axrowland
I have the same problem of a burner that gets WAY too hot on a Whirlpool gr440lxmb0. DO you have the part I would need to replace?
#5 Posted : Thursday, December 17, 2009 3:22:26 PM(UTC)
This is a duplicated post.
Answered here: http://forum.appliancepartspros...ets-excessively-hot.html
jr_sanford
#6 Posted : Saturday, December 19, 2009 11:42:10 AM(UTC)
jr_sanford
Hey Gene, we're having the same problem with our Frigidaire® cook top stove. No matter what we set the control to, it goes to HIGH heat. The connector seems loose in the metal holder like the melted holders to the bracket are wiggly now. :eek: Perhaps you might know a part number for this?
Thanks,
J.R.
Guest
#7 Posted : Friday, September 10, 2021 3:54:34 PM(UTC)
Guest
Rank: Guest
United States
Ue5abh3v ok
Guest
#8 Posted : Monday, April 24, 2023 3:55:06 PM(UTC)
Guest
Rank: Guest
United States
Had same problem, replaced it and a year later same problem again!
