After removing and defrosting the ice maker unit. It would go through all the motions except add water. The ice water dispenser worked. I replaced the valve inlt unit, but still no water to the ice tray. Is the line that runs up the back and outside of the regrigertor the line feeding the ice maker our does it go through the filter? Thanks
Yes if does feed through the water filter but if you get good water pressure to the water dispenser the filter is not the problem. Look in the tube that enters that feeds the icemaker water. If it is stopped up with ice remove the ice and you problem will be fixed. The water valve is typically what would cause this problem and you already replace that. Refrigerator repair guide
