Flastagehand
#1 Posted : Saturday, January 19, 2008 10:43:44 AM(UTC)
Flastagehand
My Whrilpool #LSR6332KQ0 will not drain or start the spin cycle, I checked the lid switch seems to be working ok, all other cycles work except for the spin cycles, Thinking it might be the timmer what do you think??????:rolleyes:
#2 Posted : Saturday, January 19, 2008 2:50:39 PM(UTC)
Does the motor run?? In spin mode.
Roper will not spin or drain (Washer Repair)
by nknibb2 5/22/2012 2:08:44 PM(UTC)
MAH8700AWW will not spin or drain (Washer Repair)
by mgterra 5/2/2012 9:39:12 PM(UTC)
by stevenkrick22 3/23/2012 4:01:07 PM(UTC)
Maytag Performa will not spin or drain (Washer Repair)
by hcoleman 6/25/2011 1:42:07 PM(UTC)
roeper washer rax4232rq4 will not spin or drain (Washer Repair)
by inoh 1/24/2011 9:51:04 AM(UTC)
Roper washer will not spin or drain (Washer Repair)
by Jfriedm 6/15/2010 5:37:38 AM(UTC)
code nd with motor running but will not spin or drain (Washer Repair)
by Nomad1 12/6/2009 9:58:51 AM(UTC)
Kenmore washer timer will not advance past the wash cycle, will not spin or drain H20 (Washer Repair)
by ambsdr4god 11/8/2009 4:12:08 PM(UTC)
Washer will not spin or drain (Washer Repair)
by templejazz82 6/24/2009 4:55:28 AM(UTC)
Will not spin or drain (Washer Repair)
by TODD39 5/16/2009 3:40:19 AM(UTC)
washer will not spin or drain - leaks (Washer Repair)
by BARCHER 4/29/2009 6:23:57 AM(UTC)
by Martha Shelby 10/23/2007 8:01:38 AM(UTC)
by Martha Shelby 10/23/2007 8:00:21 AM(UTC)
