stevenkrick22
#1 Posted : Friday, March 23, 2012 4:01:07 PM(UTC)
stevenkrick22
last night i started a load of landry and when i woke up this moring the washer was still half way fill up with the dirty water in it . when u put it on spin all it does is hum a little but that it what can it be
Simon / APP Team
#2 Posted : Friday, March 23, 2012 4:13:16 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Take off the front panel and check if the drain pump is running.
Check all the drain hoses and the sump.
Most likely there is a clogged drain or pump.
For further assistance provide complete model number.
Thank you. Post the results.
stevenkrick22
#3 Posted : Sunday, March 25, 2012 4:52:59 AM(UTC)
stevenkrick22
thanks for the advise i found the clogged hose thank you again
Simon / APP Team
#4 Posted : Monday, March 26, 2012 9:42:06 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Roper will not spin or drain (Washer Repair)
by nknibb2 5/22/2012 2:08:44 PM(UTC)
MAH8700AWW will not spin or drain (Washer Repair)
by mgterra 5/2/2012 9:39:12 PM(UTC)
Maytag Performa will not spin or drain (Washer Repair)
by hcoleman 6/25/2011 1:42:07 PM(UTC)
roeper washer rax4232rq4 will not spin or drain (Washer Repair)
by inoh 1/24/2011 9:51:04 AM(UTC)
Roper washer will not spin or drain (Washer Repair)
by Jfriedm 6/15/2010 5:37:38 AM(UTC)
code nd with motor running but will not spin or drain (Washer Repair)
by Nomad1 12/6/2009 9:58:51 AM(UTC)
Kenmore washer timer will not advance past the wash cycle, will not spin or drain H20 (Washer Repair)
by ambsdr4god 11/8/2009 4:12:08 PM(UTC)
Washer will not spin or drain (Washer Repair)
by templejazz82 6/24/2009 4:55:28 AM(UTC)
Will not spin or drain (Washer Repair)
by TODD39 5/16/2009 3:40:19 AM(UTC)
washer will not spin or drain - leaks (Washer Repair)
by BARCHER 4/29/2009 6:23:57 AM(UTC)
Will not Spin or Drain (Washer Repair)
by Flastagehand 1/19/2008 10:43:44 AM(UTC)
by Martha Shelby 10/23/2007 8:01:38 AM(UTC)
by Martha Shelby 10/23/2007 8:00:21 AM(UTC)
